    • Subscribe!
Banner Engineering Low-Profile Strip Lights is Illuminate Machine, Work Spaces, and Mobile Equipment
By Maddie Lippert | August 4, 2017
Banner Engineering today announced the release of the WLS15, a professional-grade LED strip light that makes it easy and cost-effective to illuminate machines, work spaces, and mobile equipment for improved efficiency and productivity.
Featuring high-efficiency LEDs and a diffuse window, the WLS15 provides bright, even illumination with no hot spots. The space-saving design of the WLS15 enables installation in confined areas and very tight spaces. It has a slim 15 mm profile that will not obstruct sight lines or disrupt the work environment.
The WLS15 uses a fraction of the energy of many comparable light fixtures and operates within the 12 V dc and 24 V dc ranges. The low power consumption and slow current draw of the WLS15 are ideal for use on mobile equipment and other battery-regulated applications.
The ability to cascade lights together combined with flexible mounting options, such as endcap mounting holes, snap clips, and a wide range of available brackets, simplifies installation and wiring and makes it easy to deploy and power one or multiple lights within a short amount of time.
Built with a sturdy aluminum inner frame and sealed in a shatter-resistant, UV-stabilized, polycarbonate shell, the WLS15 resists impact and vibration and tolerates wet and dirty conditions. This rugged, IP67-rated light fixture will perform reliably in challenging indoor and outdoor environments.
The WLS15 is certified for use around the world and is supported by Banner Engineering’s global network of offices and partners. This simplifies repair and replacement by ensuring easy local access to service, support, and spares, if ever needed.
For more information, visit:
Banner Engineering
www.bannerengineering.com
Filed Under: TECHNOLOGIES + PRODUCTS, Flanges • supports • mounts • brackets
Tagged With: bannerengineering
Product Image of the NTE2620
Acromag expands its line of ethernet remote I/O modules
Beckhoff’s EPX series EtherCAT I/Os provide intrinsic safety in IP67 form factors
Softing introduces OPC UA-based OT/IT integration solution with MQTT connection
Southco introduces stylish corrosion-resistant stainless steel positioning hinge
    • Subscribe!
