Banner U-GAGE® M25U Ultrasonic Sensors
By Patrick Curran | April 15, 2009
Minneapolis, MN–Banner Engineering Corp. introduces U-GAGE® M25U Ultrasonic Sensors, opposed mode ultrasonic sensor pairs specifically designed for use in sanitary environments. The sensors, rated IP69K, IP67 (NEMA 6), are constructed of heavy-duty 316 stainless steel, allowing them to withstand the recurring high-pressure washdowns, severe temperatures, and aggressive cleaning chemicals common in food and beverage applications.
With a smooth barrel housing–free of threads, gaps or seams that could accumulate debris–M25U sensors allow for thorough cleanup with minimal effort. Additionally, IP68-rated washdown cordsets and FDA compliant brackets are available to further ensure reliable, long-lasting performance in the harshest environments.
M25U sensors can be wired for either normal or high speed. Normal speed offers a longer sensing range, while high speed provides a shorter response time, ideal for high-speed counting applications.
www.bannerengineering.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
mti
MTI
moog
