Banner Engineering WORLD-BEAM® QS30H2O Opposed Mode Water Sensors provide an innovative solution for efficiently detecting water-based liquids in clear, frosted, colored or even partially opaque bottles or containers. QS30 Water Sensors use a specially designed 1450 nm sensing beam, which is inherently absorbed by water, to make the previously challenging clear bottle/clear water combination detection a high-contrast application, enabling reliable detection. In addition, QS30 Water Sensors have high excess gain to “burn through” colored glass, labeled/decorated bottles and translucent milk jugs to detect the liquid contents.
QS30 Water Sensors consist of an emitter and a choice of either a low-power receiver, ideal for detecting water in clear bottles, or a high-power receiver, designed to effectively receive the emitted beam through partially opaque containers. In addition, the 13 mm diameter beam can be shaped using one of the three apertures that come standard with each emitter/receiver pair. The aperture reduces excess gain and narrows the sensing beam, facilitating accurate detection of water in vials, test tubes or other small vessels and containers. Pricing for a QS30 Water Sensor emitter/receiver pair begins at just $285.
Banner Engineering
www.bannerengineering.com
Filed Under: Sensors (position + other), Test + measurement • test equipment
