Economical SOLO Basic temperature controllers provide single loop control for heating and cooling processes using a thermocouple or RTD input signal and a relay, voltage pulse, or current output signal (depending on model).
The 1/16 DIN panel size SOLO basic controller operates on 100 to 240 Vac 50 / 60 Hz input power. Two 4-character 7-segment LED displays indicate process value (PV) and setpoint value (SV); red for PV and green for SV (°F or °C selectable). These basic controllers are IP66 rated for dust and water jet ingress protection (inside suitable enclosure) and have a 0°C to 50°C operating temperature range.
SOLO Basic units accept 11 types of thermocouples, 4 types of RTD temperature sensors, and support three control modes: PID, ON/OFF, and Manual. An Auto Tuning (AT) function is available with PID control. On select models there are two alarm outputs available with nine selectable alarm types. Models with alarm outputs can also be configured to use one of the alarm outputs as a second control output, allowing both heating and cooling control or two-stage heating or two-stage cooling control.
AutomationDirect
www.automationdirect.com/basic-temp-controllers
