Batchmaster IV Counter verifies the 3D volume of each part in real-time
By Michelle Froese | October 14, 2022
To learn more, download the Batchmaster IV Continuous Counter’s datasheet here.
Batching Systems‘ Batchmaster Counters are the only counters that use patented dual-view scanners that provide the highest accuracy count possible. This means out-of-tolerance parts are rejected prior to entering a package. What’s more, the counting system is three times faster than other systems on the market with four times greater accuracy.
The newest Batchmaster IV Continuous Counter offers an accurate high-speed counting system that detects and rejects parts one-third smaller or larger than a target part — separating the good parts from the bad.
The processing unit is designed with a transparent front panel for visual inspection of gate movement and product flow. These counters can easily integrate with upstream and downstream packaging equipment. Batching systems can also provide standalone counters or fully integrated turnkey packaging systems.
The Batchmaster IV Counter also now includes bar-code reading and recipe management. Advanced programming and a large 10.4-inch color, touch-screen provide a user-friendly intuitive set-up, data monitoring, self-diagnostics, verified motion control technology, remote access, multi-language options, and custom password lock outs.
Standard features
  • Patented dual view optics, 3-D imaging
  • Continuous run operation with touch-screen controls — typical product changeover is two minutes or less
  • In-flight volume analysis and high resolution scan
  • Self-diagnostics, with out-of-tolerance reject multiple dump feature
  • Storable set-up parameters
  • Hydraulic stand on casters
  • Compatible controls, no changeover tooling
  • Expandable network
  • Virtually no wear parts, servo motors with no linkages
Tagged With: batchingsystems
