The ITT Veam CIR M12 connector can transfer data from Ethernet, WTB, and MVB in a single connector. It meets increasing data transmission requirements while delivering optimal sealing and extreme shock vibration resistance in the harshest environments.
The bayonet coupling circular connectors are ideal in harsh environments.
This high speed connector solution is a combination of M12 contacts mounted into Veam FRCIR connector series hardware.
Supporting gigabit communication, the CIR M12 enables transfer of data from Ethernet, MVB, WTB, and Video lines, according to VG95234, within the same connector.
Additionally, the ITT Veam Power Plate has a compact, fully customizable design ideal for applications where a minimized footprint is required, such as connection of the railcar to bogies, traction motors and converters.
Finally, ITT’s Veam CIR Blue Generation RoHS compliant plating delivers best-in-class durability, conductivity and shielding performance. It is able to withstand temperatures between –55° and 125° C, and is available on all aluminum-based ITT Veam connectors.
ITT Cannon
www.ittcannon.com
Filed Under: Connectors (electrical) • crimp technologies
