Morgan Hill, CA – All Sensors Corporation announces the release of the BDS (Basic Dual Sensor) Series Pressure Sensor. The BDS (Basic Dual Sensor) Series Pressure Sensor is comprised of two independent sensors in a single package. This device is capable of measuring both an absolute and differential pressure source. This marks an industry first for the pressure sensor market. For the first time an engineer can obtain an absolute and differential pressure reading simultaneously from one device. By combining the functionality of two devices into one, physical space is spared on the customer’s PC board resulting in minimal pneumatic and mechanical
difficulties. The BDS Series Pressure Sensor is RoHS compliant.
The sensors are offered in a pc board mountable package with two pressure ports. Port volumes have been balanced to improve common mode response. This package is designed for high common mode pressure. This device can accommodate high burst pressure for extended dynamic range capability. Ports are compatible with Honeywell SCC or N-Package and Motorola MPX devices.
The sensors are available with a basic millivolt output. Output offset and temperature errors are significantly reduced by electrically cross coupled sensing elements. Absolute and differential pressure outputs are provided simultaneously.
www.allsensors.com
Filed Under: Sensors (pressure), TEST & MEASUREMENT
