Bearing dismantling in new MiHow2 video
By Mike Santora | July 2, 2015
MiHow2-Koyo-Bearing-DismantlingMotion Industries has announced the release of a new MiHow2 video. The goal of the video series is to provide instruction to viewers to help them with their practical applications.
“Proper Bearing Dismantling Procedures Using a Mechanical Puller,” which was filmed with an expert from Koyo Bearing, can now be viewed on the new MiHow2.com under the MiHow2 heading. The video demonstrates how to safely and efficiently remove a bearing from a shaft using a mechanical puller.
“The mechanical puller enables the user to remove the bearing safely and without damaging other parts of equipment,” said Randy Breaux, Motion Industries’ Senior Vice President, Southern U.S. Operations, Corporate Marketing and Strategic Planning. “Removing bearings correctly helps keep downtime to a minimum.”
Each MiHow2 video is filmed in a workshop or appropriate off-site setting and features Motion Industries’ host, Tom Clark, and a guest from one of the market leading manufacturers demonstrating a product or application.
The series is also available for viewing via Facebook and YouTube. Additional MiHow2 videos
are scheduled to be posted in coming weeks.
Motion Industries
www.motionindustries.com
The post Bearing dismantling in new MiHow2 video appeared first on Bearing Tips.
Filed Under: Bearing Tips
Tagged With: motionindustries
Navigating the global bearing shortage
Wear-resistant and quiet: igus develops a new two-component ball bearing
Vesconite manufactures largest Vesconite Hilube stern tube / propeller shaft bearing to date
Schaeffler adds new split cylindrical roller bearing housed assembly
