Boca Bearings Company has announced the release of a ceramic bearing line specially designed for the harsh environments and machinery used in waste water management, water treatment, and liquid handling. Boca Bearings offers bearings that can work in different types of machines and steps of the fluid handling process.
The ceramic bearings require little to no lubrication or other maintenance and therefore can be applied in different water/fluid handling machinery, such as pumps, flow meters, and hydraulic equipment. As ceramic bearings do not corrode or rust they can be used with different chemicals, from ion or sodium to alkali. Since these bearings are virtually maintenance free they will reduce and minimize bearing related down time of plant’s equipment.
All bearings can be supplied without lubrication or with specialty lubricants such as a solid poly lube or ultra dry lube. This will allow the bearings to be used in well equipment and purified water or water ready for consumption.
Boca Bearings
The post Bearings for wastewater management, water treatment, and fluid handling appeared first on Bearing Tips.
Filed Under: Bearings, Hydraulic equipment + components
