    • On the Floor
Beckhoff Automation Announces TwinCAT Remote Synchronization
By Design World Staff | December 5, 2006
MINNEAPOLIS, MN — In order to help streamline controls design for the most dynamic machine control applications, Beckhoff Automation has announced TwinCAT Remote Synchronization. With this new software library of function blocks, users can more easily synchronize several multi-axis machines that have TwinCAT control systems. This solution is ideal for synchronizing systems that control dozens of axes or only a few. TwinCAT software for PLC and Motion Control is fully functional with any open industrial PC and all Beckhoff Embedded PCs.
While a centralized control architecture using one industrial PC and TwinCAT software is suitable for applications with 60 axes of motion or more, there are cases where more than one PC controller is required for multiple machines in a line. The TwinCAT Remote Synchronization Library allows for general time synchronization of information for distributed control to coordinate multiple machines by calculating offsets to compensate for differences in execution time and CPU clock frequencies. In addition, the library includes special techniques for synchronizing NC axes distributed axes and electronic gearing of axes on separate controllers.
Established system used across the globe
For several years, TwinCAT software from Beckhoff Automation has brought users around the world the ability to turn any compatible PC into a real-time controller with a multiple PLC system, NC axis control, programming environment and operating station. TwinCAT replaces conventional PLCs, NC/CNC controllers and operating devices with open, PC hardware. Several programming environments are available within TwinCAT through compliance with IEC 61131-3, the only global standard for industrial controls programming.
For more information (including TwinCAT 2.10 demo download):
www.beckhoffautomation.com/twincat
:: Design World ::
Filed Under: Factory automation, ENGINEERING SOFTWARE, Motion control • motor controls, PCs
  • Toyota goes all-in on humanoid robots
  • Mobile robotics moves to the textile industry
  • Finally, hard data on humanoid robot cost in the factory
    • On the Floor
