Beckhoff EL922x EtherCAT I/O for system-integrated overcurrent protection
By Lisa Eitel | December 14, 2017
Beckhoff now sells EL922x EtherCAT Terminal series, which directly integrates electronic overcurrent protection to safeguard 24 V DC system components in the EtherCAT I/O system. In comparison with currently available protection devices, costs and space requirements in control cabinets can be reduced without having to use conventional, inflexible stand-alone systems.
With an extended range of settings and process data options, the 12-mm wide EL922x EtherCAT Terminals meet the most diverse requirements and enable transparent system monitoring.
More on the EL9227 EtherCAT Terminal
More on the EL9222 EtherCAT Terminal
More on the EL9221 EtherCAT Terminal
The EL922x Terminal series for overcurrent protection is designed for 24 V DC operation and includes 19 different EtherCAT Terminals. There are 1- and 2-channel versions for various current loads up to a maximum of 10 A. The wide range of terminals includes:
1. EL9221 and EL9222 Terminals with standard functionality such as rated current, which can be parameterized not only using TwinCAT System Manager software, but also conveniently with an LED button.
2. EL9227-xxxx Terminals with extended functionality that can be parameterized in the TwinCAT System Manager, such as the selection of a characteristic curve, preliminary warning threshold, undervoltage signal, feedback cut-off, event logging and a password-protected software seal.
System-integrated overcurrent protection offers numerous practical benefits for users. Wiring effort is reduced since the feed into adjacent I/O terminals is achieved automatically by simply plugging in the terminal. In addition, control cabinets benefit from space and cost savings because additional coupling hardware and other digital I/O or power feeding products are no longer required.
Numerous types of process data are accessible via EtherCAT, for example utilization rate, load current, input/output current, undervoltage and overvoltage, and feedback. This enables transparent system monitoring, minimized downtime, simplified troubleshooting and a comprehensive overview of plant history.
You may also like:
  • Beckhoff expands ultra-compact industrial PC series with the new C6030
  • Beckhoff Automation Introduces TwinCAT Vision Software
  • Industrial Ethernet—a version for every application
  • What’s the difference between an industrial PC for motion control…
  • Webinar: Industrial Ethernet technology redefined: One Cable Automation delivers power…
Filed Under: Mechatronic Tips, I/O modules
Tagged With: beckhoff
Lisa Eitel
Lisa Eitel has worked in the motion industry since 2001. Her areas of focus include motors, drives, motion control, power transmission, linear motion, and sensing and feedback technologies. She has a B.S. in Mechanical Engineering and is an inductee of Tau Beta Pi engineering honor society; a member of the Society of Women Engineers; and a judge for the FIRST Robotics Buckeye Regionals. Besides her motioncontroltips.com contributions, she also leads the production of the quarterly motion issues of Design World.
Io-link-Smartfield
IO-Link Smart Field I/O System from AutomationDirect
Beckhoff I/O terminal supports high-voltage measurement for renewable energy and EV technologies
Opto 22 releases groov RIO EMU distributed energy monitoring unit
Opto 22 releases new groov EPIC I/O modules for large-scale power monitoring, signal integration
