Bellows couplings for robotics
By Mike Santora | February 19, 2025
Ruland bellows couplings are ideal for precision motion in robotic applications due to their zero-backlash design, high torque and torsional stiffness, and various styles that ensure accurate movement and smooth operation. They are commonly used in industrial, medical, and autonomous robotic systems requiring high speed and accuracy.
Ruland-bellows-couplings
Ruland bellows couplings are designed for high-torque and zero-backlash applications, which are essential for robots requiring precision motion control. These couplings are lightweight, have low inertia, and can accommodate all forms of misalignment, making them highly versatile for different robotic applications.
Designers benefit from using Ruland bellows couplings because they have reduced vibrations at speeds up to 10,000 rpm due to a balanced design. They are also available in standard lengths for increased torsional stiffness and extended lengths for increased misalignment capabilities. These options allow designers to use the bellows coupling that best fits their application.
Ruland bellows couplings are available in clamp-style designs, with bore sizes ranging from 1/8 in (3 mm) to 1-3/4 in (45 mm). Hubs are manufactured from meticulously selected 2024 T-351 aluminum bar stock for high strength and low inertia. Bellows are made from stainless steel, giving the coupling flexibility under torsional loads. Each coupling undergoes a proprietary assembly process to ensure it does not introduce misalignment, causing high bearing loads into the system.
Ruland carefully manufactures bellows couplings in its ISO 9001:2015 certified advanced manufacturing facility in Marlborough, Massachusetts, using strict controls and proprietary processes. They comply with RoHS3, REACH, and Conflict Minerals, ensuring they meet global environmental sustainability and safety standards.
Summary: Why Ruland bellows couplings?
Ideal for precise motion in robotic systems, offering high torque and torsional stiffness
Reduced vibration at speeds up to 10,000 rpm due to a balanced design
Long lengths for increased misalignment and standard lengths for maximum torsional stiffness
Carefully made in Ruland’s Marlborough, Massachusetts advanced manufacturing facility
Available for immediate delivery
RoHS3, REACH, and Conflict Minerals-compliant
Ruland
www.ruland.com
Filed Under: Coupling Tips
Tagged With: Ruland
