Benefits of Using Stainless Steel
By Design World Staff | October 31, 2008
Eagle Stainless Tube & Fabrication has been a leading supplier of ultra high precision, cut-to-length, stainless steel for over 26 years. There are numerous benefits of using Stainless Steel. Corrosion resistance of both low and high alloyed grades, fire and heat resistance, hygiene, aesthetic appearance, strength-to-weight advantage, ease of fabrication, and impact resistance. Engineers, specifiers and designers often underestimate or overlook these values because of what is viewed as the higher initial cost of stainless steel. When the total life cycle costs are considered, stainless is often the least expensive material option.
www.eagletube.com
