Despite its extremely compact package, Beswick’s (www.beswick.com) Subminiature Pressure Regulator delivers excellent pressure regulation.
Allowing relatively precise pressure regulation, the Subminiature Pressure Regulator offers an outside dimension that is similar to that of Beswick’s 10-32 threaded needle valves. For leak tight connections, the inlet port features a 10-32 external thread and an O-ring face seal. The regulator’s outlet port allows for easy connection since it is adjustable. The device can also be supplied in a number of configurations such as elbows, tees, manifold mount and crosses as well as a vast array of connection styles such as compression connections, tube barbs or push to connect connections.
Aside from its subminiature envelope, Beswick’s Subminiature Pressure Regulator is made entirely of stainless steel and is offered with a vast array of elastomeric seals, which allow excellent thermal resistance and fluid compatibility.
Meanwhile, its patent pending valve design enables the device to accurately regulate pressures, much like larger devices.
The Subminiature Pressure Regulator is ideally suited for use in various applications such as in medical and dental equipment, fuel cell industry, instruments and laboratory equipment. It also works well with applications in aerospace equipment, semiconductor manufacturing equipment, industrial robots and packaging machinery.
Beswick manufactures and designs high-performance miniature fluid power components such as valves, quick disconnects, pressure regulators/gauges, fittings, cylinders and orifices. Its offerings also include shock absorbers, tubing and pressure electric switches.
Filed Under: Pneumatic Tips
