Better Catalysts For Heavy Oil Extraction
By Kazan Federal University | February 1, 2016
The catalysts speed up heavy oil extraction under the conditions of in-situ combustion.
Projected heavy oil and viscous oil reserves in Russia are up to 40 — 50 billion barrels and a significant portion of that volume lies within Tatarstan. Heavy oil extraction warrants special technological processes, and research in that direction is currently becoming the center of attention in heavy oil-rich countries (USA, Canada, Venezuela, Russia).
Researchers at Kazan University cooperate with their peers from Stanford University. Their latest results were published in Energy and Fuels.
Senior Researcher at the Interbedding Combustion Lab Andrey Galukhin speaks about the research:
“Calorimetric experiments show that crude oil with higher saturate content and low resin fraction has higher heating value. Additionally, the crude oils undergo two major transitions when subjected to an oxidizing and constant rate environment known as low- and high-temperature oxidations at each heating rate studied. There are ways to pump extremely hot steam into a reservoir to liquefy viscous oil, what facilitates the extraction. However, there are limitations — if the reservoir more than 1 km deep, steam loses most of its heat energy. That is why in-situ combustion is interesting for us — the heat for liquefying is generated in the reservoir. Our group works on catalysts that provide combustion during this process. The catalysts help to oxidize oil deposits in reservoirs that are relatively resistant to burning.”
Dr. Galukhin won a grant for this particular work from the Russian Foundation for Basic Research in 2015.
The catalysts developed by the group have already shown promising results in lab tests, and the work continues.
