Better Control for Air Cylinders
By Design World Staff | December 16, 2009
Air cylinder controls, a common component used to control motion, typically include airflow control valves to regulate the air pressure to produce a specified speed. Compressed air, though safe, economical and readily available, is by its nature, unstable, presenting challenges to precise control.
The Kinechek® hydraulic speed regulator used as an accessory with an air cylinder controlled system, achieves constant, precise motion. This regulator controls the air cylinder piston rod to move at a constant feed rate and requires no maintenance due to its hermetically sealed, leakproof design. The “feed rate” can be changed to suit various speed requirements by simply turning the built-in adjustment knob.
Deschner Corporation
www.deschner.com
Filed Under: Fluid power, Linear motion • slides, Pneumatic equipment + components
LM76-SPEED DEMON EL300 4x5x300
LM76 SPEED DEMON EL300 for high speed, low friction, smooth linear motion
Stainless steel linear guide rail systems
LWLF2_FAM
IKO’s New LWLF2 Miniature Linear Guides
igus introduces self-lubricating toothed belt axis designed for clean use in food technology
