BigRep, a global leader in large-format 3D printers and additive solutions, will introduce four new BigRep certified materials at FABTECH in Chicago (November 11 – 14, 2019, BigRep booth A 4350). These new materials – PLX, PET-CF, PA6/66 and BVOH – support BigRep’s mission to provide cost-effective and environmentally friendly engineering-grade materials to large-format additive manufacturing.
BigRep PLX addresses the industry’s need for a fast, reliable and environmentally friendly material. The material is a general-use bio-performance filament derived from organic compounds suited for open-environment 3D printing. Best suited for design and functional prototyping, BigRep’s PLX can print up to 80% faster than standard PLA with no modification to the 3D printer at a strength surpassing the typical mechanical properties of even ABS-printed parts.
The second new material, PET-CF, is a carbon fiber reinforced filament introduced to BigRep’s growing line of engineering-grade materials for high-strength, large-format printing. Offering exceptional dimensional stability and low moisture absorption, PET-CF is capable of producing exceptionally strong, stiff parts with a fine surface finish and heat resistance up to 100 °C. Designed for the BigRep STUDIO G2, the material is suitable for functional, performance applications.
BigRep’s PA6/66 is a highly durable, lightweight thermoplastic filament with high rigidity and resistance to heat and chemicals. Its compatibility with machining and mechanical strength make it a candidate for many industrial applications like tooling, patterns, molds and end use parts. Functionally similar to Nylon PA6, a common material for injection molding, PA6/66 is uniquely suited for scalable batch productions, printing end-use parts or prototyping with nearly identical material properties to mass production parts.
BigRep’s BVOH support material is an advanced water-soluble filament that eliminates support removal post processing for complex 3D-printed parts. Due to BVOH’s solubility and ability to support heavy prints, it is suited for printing complex, ready-to-use prototypes.
With open-source material compatibility, BigRep printers suit industrial users with advanced or niche material requirements. BigRep continues to expand its filament offerings, enabling users to produce large-format parts with advanced, engineering-grade materials. By introducing and supporting the engineering-grade materials our industrial users require, BigRep continues to expand its additive systems’ capabilities to enable the advanced applications and efficient workflows that help businesses grow and prosper.
BigRep
www.bigrep.com
Filed Under: Molding • injection molding components, Uncategorized
