Bimba Manufacturing Company announced the expansion of its industry-leading Original Line® product series. Previously available in only 4 bore sizes, Bimba extended its All Stainless Original Line series to now include all 12 bore sizes currently available across the product line (5/16” bore through 3” bore).
Featuring stainless steel end caps, standard urethane wipers, PTFE-based rod and pivot bushings and food-grade synthetic grease, this non-repairable actuator is ideal for wash down application environments common in the food processing industry.
“While these cylinders have been designed with the food and beverage industry in mind, their all stainless steel construction makes them ideal for any application that requires corrosion resistance,” said Jerry Scherzinger, Bimba’s Product Marketing Manager. “This is a natural expansion of our line of all stainless steel actuators that will provide a wider range of sizes for our customers requiring corrosion resistant designs.”
Bimba Manufacturing
www.bimba.com
Filed Under: Fluid power, Hydraulic equipment + components, Linear motion • slides, Pneumatic equipment + components
