    • Subscribe!
Binder USA expands M12 family with K- and L-coded power cable and panel-mount connectors
By Mary Gannon | February 27, 2018
Binder-520_M12-K-code_300-dpi
Binder’s M12 K-code connectors
Binder USA LP has expanded its M12 product family with the addition of the M12–L, a dc power supply Profinet compliant connector, and the M12-K, an ac power supply connector. The cordsets are ready to mount with preassembled male and female panel mount connectors. M12 power connectors are commonly used for industrial networks in process and manufacturing automation.
The M12-K and M12-L are IP67/IP68 in mated condition, ensuring protection from liquids and debris, with a standard wire length of 200 mm. Gold-plated contacts provide low contact resistance and each receptacle is prewired with 16-gauge wires using UL PVC wiring. The K-Coded version is rated up to 630 Vac, 12 A per contact and the L-Coded rated up to 63 Vdc, 16 A.
Binder-520_M12---L-code_300-dpiBinder-520_M12---L-code_300-dpi
Binder’s M12 L-code connectors
M12-K /M12-L highlights include:
  • Gold-plated crimp contacts: 4+PE (M12-K)/4+PF (M12-L)
  • 12 A, 630 Vac (M12-K)
  • 16 A, 63 Vdc (M12-L)
  • UL approval, CSA and VDE in preparation
  • IP67 and IP68 in mated condition
  • UL PVC single wires AWG 16 Style 1007/1569
Binder USA LP
www.binder-connector.us
Filed Under: Cables + cable management, Connectors (electrical) • crimp technologies
Tagged With: binderusa, stratasysdirectmanufacturing
molex-versablade-300x300
Heilind Electronics now offering Molex VersaBlade Wire-to-Wire Connector System
bel-stewart-m12xcode-connector
Stewart Connector M12 X-Code PCB mount connectors
Heilind-electronics-product-image
Heilind Electronics now offering Molex PowerPlane BusBar Power Connectors
Harting Technology Group heads for a climate-neutral future with record investment
    • Subscribe!
