    • Subscribe!
binder USA introduces M12 K- and L-coded connectors for North America
By Mary Gannon | June 13, 2022
binder USA introduces the 823 and 824 series M12 cable connectors, designed to meet the testing and certification requirements of the North American market. These compact M12 K- and L-coded connectors include both male and female cable and angled connectors. They feature M12x1 threads, 8-mm to 13-mm cable outlets, and IP67-rated screw clamp terminals. To comply with UL 2237 requirements, the threaded ring is electrically connected to the PE contact.
BIN_binder-USA_M12-K&L_300-dpiK-coded 5-pin connectors are ideal for power supply in AC applications, such as drives or frequency converters. L-coded 5-pin connectors are ideal for DC compact drives, decentralized I/O modules and various DC-powered automation components connected to fieldbus systems.
Product highlights:
  • Cable outlets: 8 mm to 13 mm
  • Termination: screw clamp
  • Protection degree: IP67
  • UL2337 and UL2238 compliant
  • K coding:
    • Pin count 4+PE
    • Rated voltage: 630 V (AC)
    • Rated current: 12 A
  • L coding:
    • Pin count 4+FE (functional earth)
    • Rated voltage: 630 V(AC)
    • Rated current: 16 A
binder US LP
www.binder-usa.com
Filed Under: Connector Tips
Tagged With: binderusa
Fully-shielded, board-to-board connector capable of 40 Gbps/lane transmission
Where are miniature connectors for wearables headed?
How are optical interconnects being miniaturized?
What connectors are there for woven electronics & e-textiles?
    • Subscribe!
