The Soft-case series of hand held enclosures from OKW (Bridgeville, PA) is now available from stock molded in Biograde bioplastic material. Biograde is a CO2 neutral material, technically compostable and biodegradable, and has similar mechanical and physical properties to ABS. On demand, OKW can also mold many of its other enclosure lines in this material. As a result, design engineers can now ensure the green credentials of their electronics by using these off-the-shelf biodegradable housings. Features include:
- Dimensions from 2.00” x 3.23” x 0.55” to 3.62” x 5.90” x 1.10”.
- Designed for wide format displays and keypads.
- Top of enclosure has wide recessed area for locating LCD or membrane keypad, and a raised panel on the long edge can be used for mounting USB, power or serial connectors and controls.
For more information, visit www.okwenclosures.com.
