St. Charles, IL – Bison Gear & Engineering Corp. has added 46 models of its 562 Series of hollow shaft offset gearmotors to its growing FlexTorq‚â„¢ line of products. With a slightly larger footprint than a conventional right angle worm reducer gearmotor, the FlexTorq‚â„¢ units provide from two to nine times more output torque, depending on the gear ratio utilized.
The 562 Series of FlexTorq‚â„¢ gearmotors is offered in seven 115 volt, single-phase 1/20 hp (37.3 watt) versions and thirty nine DC versions with 12, 24, 90 and 130 volt inputs and powers of 1/8 and 1/20 hp (93.2 and 37.3 watts). Continuous output torques range from 66 to 1100 in-lbs (7.5 to 124.3 N-m), with corresponding fixed output speeds from 65 to 1.3 rpm.
www.BisonGear.com
Filed Under: Motion control • motor controls, Motors (gearmotors)
