Oriental Motor introduces the BLV Series, a DC input, high power brushless motor and driver system with connection cable. The BLV Series is available with either a 200 watt (1/4 hp) or 400 watt (1/2 hp) motor, in round shaft, parallel gear or our new 104 mm (4.09 in) flat hollow shaft (FR) gear with a speed range of 100 ~ 4,000 r/min.
The BLV Series is the first Oriental Motor brushless motor and driver system to offer a DC input above 100 watts and is available with an electronic brake for holding during standstill or gravitational operations. The BLV Series is also equipped to facilitate a battery power input. Operations are handled through an I/O control system or RS-485 communications. Functions can be expanded with use of the OPX-2A controller allowing for improved speed regulation, programming and various display functions.
Additional features include:
• DC Power Input
— 24 volt – 200 watt (1/4 hp)
— 48 volt – 400 watt (1/2 hp)
• Extended Functions with the OPX-2A (sold separately)
— 80~4000 r/min (100 ~ 4,000 basic)
— + 0.2% speed regulation
— Set up to 8 data digital settings
— Display / Monitoring function
• Torque Control
— Standard option, ability to change the motor torque, 0 to 200%
— Used for push motion or holding
— Set by pot on driver (VR3) or by RS-485 or OPX-2A
Oriental Motor
www.orientalmotor.com
Filed Under: Motion control • motor controls, Motors • dc
