Bodine Electric Upgrades High Torque CG Gearmotor
By Miles Budimir | December 9, 2009
CHICAGO, IL — Bodine Electric Company has upgraded and expanded its Type-CG variable speed AC inverter-duty and permanent magnet DC gearmotors. The CG gearmotors are designed for applications such as heavy-duty conveyor systems, medical equipment, food processing and factory automation, where long life and high load capacity are critical.
The CG gearhead is paired with Bodine’s most powerful variable speed electric motors, the 48R6, AC inverter-duty, and 42A7 permanent magnet DC motors. This integral gearmotor design allows the CG to deliver up to 1,000 lb-in. of torque, which is nearly twice the torque of any previous Bodine product.
The CG gearmotor features a solid, aluminum cast gearhousing. It can be face-mounted in virtually any position, or mounted with a rigid base. Extra heavy-duty bearings and seals provide reliable operation and long life. Inside the gearhead three-stage, selectively hardened gearing and high performance lubricant insure quiet operation and high output torque. New DC accessory-ready models can be fitted with encoders, other feedback devices, or brakes.
The AC and DC models are the first of Bodine’s product line to be available through their new Quick Delivery program. This program is designed to ship customer orders in small order quantities within two to three working days. Products will be maintained in stock or assembled to order via a quick-turn production cell. Larger order quantities will require lead-time. Expedited delivery options are also available.
www.Bodine-Electric.com
Filed Under: Motion control • motor controls, Motors (gearmotors)
Comments
  1. Marvin Wilson says
    September 16, 2016 at 8:15 pm
    I’m making a homemade smoker with a rotisserie, this motor looks like just what I want……what are the RPM speeds on the CG motor and do you have speed control dials to attach?
  2. asim shabbir says
    April 27, 2018 at 1:30 am
    Dear sir.
    i want to make a water well drilling rig .is this ac motor do that .whats the rpm of this motor.how much torque we give from it.also show me the heavy duty high speed high torque motor.
    regards
    Asim shabbir
49503-ACS Motion-CMxa
SDP-SI-040
PACMotion-servos
