Boker’s Announces Tab Washers are Now Available
By Design World Staff | May 17, 2011
Boker’s, Inc. announces that tab washers, offered in a wide variety of sizes and materials, are now available as part of their washer manufacturing capability. Tab washer sizes include outside diameters ranging from .080 inches to 6.000 inches, in addition to multiple inside diameter and thickness options, allowing tab washer compatibility with all types of nuts, bolts and other fastening systems. Boker’s manufactures numerous configurations of tab washers including: internal tab, external tab, internal/external tab, multiple internal/external tab, and locking tab washers.
Tab Washers
Tab washers are a type of lock washer, round in shape and often manufactured with a single tab or multiple tabs that can be formed to shape around bolts/nuts or designed to lay flat. Ideal for use in harsh environments, tab washers effectively lock a part into place in applications requiring extreme heat conditions or heavy vibrations.
Boker’s custom manufactures tab washers to customer specifications, offering tab washers in 2,000 commonly specified and difficult-to-find materials, including metallic and non-metallic materials. Metallic material options include low-carbon sheet steel, various spring steels, stainless steel, aluminum, brass, copper and nickel silver. Non-metallic material options include ABS, acetal, polyester, nylon, nylon MD, polycarbonate, fiber, polyethylene and various NEMA grade laminates. With quick turnarounds and millions of washer possibilities, Boker’s offers washer solutions to suit a wide range of application needs.
Boker’s, Inc.
www.bokers.com
Filed Under: Fastening + joining • locks • latches • pins, Washers • spacers
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
Going small with 3D printing
