Boker’s Offers Metric Washers in 2,000 Materials
By Dave Miyares | January 26, 2012
Boker’s, Inc. announces metric washers are available in 2,000 materials. Via their easy-to-navigate website, users can browse Boker’s extensive flat washer offering in either millimeters or inches for enhanced application compatibility and ordering convenience.
Bokers-washer
Through Boker’s online search tool, users can mandate washer criteria by selecting the appropriate unit of measurement and material, as well as designate inside/outside diameters and a thickness range. Metric washer searches can be expedited by narrowing the company’s vast washer selection to sizes appropriate for specific applications. With washers available in outside diameters ranging from 2.03 mm to 130.55 mm and a variety of inside diameters and thicknesses, clients can select the ideal metric washer for virtually any application. Along with their helpful conversion chart featured on the back of their 2012 Calendar and Boker’s new metric edition of the 2012 Washer Catalog, the website offers another useful, yet simple, avenue for clients to order metric washers.
Manufactured in over 26,000 non-standard flat washer and spacer sizes and with over 2,000 commonly specified and difficult-to-find material options, Boker’s provides metric washers to clients’ exact specifications. Metallic material options include low-carbon sheet steel, various spring steels, stainless steel, aluminum, brass, copper and nickel silver. Non-metallic options include ABS, acetal, polyester, nylon, MD nylon, polycarbonate, fiber, polyethylene and various NEMA grade laminates. With quick turnarounds and millions of washer possibilities, Boker’s offers washer solutions to suit a wide range of applications.
Boker’s, Inc.
www.bokers.com
Filed Under: Fastening + joining • locks • latches • pins, Washers • spacers
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
Omron D41D high-coded non-contact door switch for safeguarding machine tools and robotic cells
