ams AG, a provider of high performance sensors and analog ICs, introduced the AS1383, an ultra-compact switching boost converter which offers high efficiency and helps extend run-time in applications powered by a single-cell lithium-ion battery.
The converter provides outputs of between 2.7V and 5.0V from a 2.7V-5.5V input voltage range. It is available with an adjustable output voltage, or a factory-programmed fixed output voltage. Depending on the input voltage, it can provide a maximum output current of up to 200mA.
The AS1383, which implements peak current-mode PWM control for accurate line and load regulation, features internal NMOS and PMOS power switches with very low on-resistance and gate charge. This helps the converter to achieve high efficiency, peaking at 92%, across the range from moderate to full loads.
In addition, it offers a clever ‘Powersave’ mode in which all circuitry except that required to monitor the output voltage is turned off when the output current falls below the point at which the energy supplied in the switch’s minimum on-time is greater than the energy consumed by the load. This Powersave mode keeps power consumption down to a typical 25µA when supplying light loads.
Operating at a high fixed switching frequency of 3.5MHz, the AS1383 requires only a small input and output capacitor and an inductor rated at just 1µH. Two additional components, external resi-stors for setting the output voltage, are required only in the adjustable-output version of the device.
The converter itself is a six-pin wafer-level chip-scale package, with a footprint of just 1.2mm x 0.8mm and a pitch of 0.4mm. This means that an AS1383-based circuit is small enough to fit in the latest sleek designs for consumer products such as wristbands, media players, digital cameras and mobile phones.
The fixed switching frequency used by the AS1383, and integrated anti-ringing control implemented in the device, help system designers to realize low-noise end product designs. At 20mV peak-to-peak for a 150mA load, output voltage ripple is also low enough to avoid interfering with sensitive downstream signals.
‘With the introduction of the AS1383, ams has achieved a remarkable combination of small solution size and high efficiency across the load range from light loads up to the maximum 200mA output current. OEMs can benefit from this to meet consumers’ demand for longer intervals between charges in the devices they use heavily’, said Bernd Krafthoefer, marketing manager at ams.
The AS1383 is available in production volumes now. Unit pricing is $0.25 in order quantities of 1,000 units.
A demonstration kit for the AS1383 is available from the ams ICdirect online shop. For sample requests and for more technical information, please go to www.ams.com/Boost-Converter/AS1383.
ams
www.ams.com
Filed Under: Power Electronic Tips
