Brad® Micro-Change® M12 Cat 6A Connector System
By Stacy Combest | August 22, 2012
Molex Incorporated introduces the robust Brad Micro-Change® M12 Cat6A connector system designed for vision systems and other high-speed data transfer applications in harsh environments. Conforming to TIA and ISO/IEC Cat 6A specifications for high-speed Ethernet signal integrity up to 10Gbps, the high-pin-density Micro-Change connector system features an innovative x-coding cross-shielding design (conforms to IEC 61076-2-109) for superior performance and transmission reliability in frequency bandwidths up to 500Mhz.
The compact sealed Micro-Change connector system features a complete 360-degree shielded design using 4-twisted pair construction. When mated, the shielding crosses of the connector and receptacle overlap to achieve optimal signal performance without system noise interference. X-coding alignment enables blind mating and recessed male pins prevent pin damage during mating. The Brad Micro-Change connector system mounts using a standard M12 threaded coupling nut. 26 AWG cable assemblies and corrosion resistant hardware assure optimal reliability in demanding environments. Rugged construction and IP67-rated external and internal O-ring seals guarantee protection against dust and water.
Molex-M12CAT6A_3_300-1
Designed for video surveillance cameras, telematics, GPS/cameras in automotive and commercial vehicles, and automated control elements, Brad Micro-Change connectors enable fast and simple replacement of 12 to 18mm sensors, encoders, switches and other I/O devices found in industrial equipment. Available in 2- through 5-, 8- and 12-pole IEC compliant configurations, single- and dual-keyway designs, with straight and 90 degree plugs, versatile
Micro-Change connectors are equally suitable for Class 2 applications. The Micro-Change sealed connection delivers superior EMI/RFI shielding in high-vibration systems, including petrochemical, factory-automation and commercial vehicle equipment. Receptacles are tooled for both network connectivity in Ethernet and Controller-Area Network (CAN bus) protocols, in addition to passive applications such as discreet and analog sensor applications.
Brad Micro-Change connectors and receptacles are compatible with numerous Molex cord sets and other harsh-duty products.
Molex Inc.
www.molex.com
Filed Under: Connectors (electrical) • crimp technologies, Electronics • electrical
Tagged With: Molex
molex-premo-flex
Going small with 3D printing
