BradControl I/O Modules Support Ethernet/IP
By Design World Staff | July 14, 2008
BradControl Classic 60 mm wide I/O modules already support connections to Modbus TCP (UDP) and now support EtherNet/IP. The module comes in an 8-port 16 channel format with the availability of multiple I/O configurations supporting both PNP and NPN input devices. The I/O module operates as a slave device in the Ethernet control system, gathering signals and data from local field devices. Each BradControl I/O module comes equipped with diagnostic LEDs providing status information on network, power, inputs and outputs.
Other features include a built-in 2-port switch for network connections, and a four digit display for addressing and status information. To facilitate input and output device wiring, BradControl Classic 60 mm I/O modules support connections using standard threaded M12 connectors or a push-to-lock mechanism to provide fast, simple, and secure connections between the I/O module and the I/O devices. The radial seal design provides a reliable, operator independent seal, eliminating the risk of under- or over-tightening.
Molex Incorporated
www.molex.com
Filed Under: I/O modules, ELECTRONICS • ELECTRICAL
