Brass Compression Limiter
By Design World Staff | March 24, 2008
Danielson, CT — SPIROL has redesigned the Series CL101 and CL111 Brass
Compression Limiter line to significantly reduce cost. The original brass
line was introduced by SPIROL in the 1990’s during the time when companies
started converting many metal assemblies over to plastic. The initial
version of the Brass Compression Limiter line was designed with a thick
wall to prevent the plastic from cracking as a result of the expected clamp
load generated by the tightening of the bolts.
Since that time, SPIROL has worked with hundreds of companies who required
a Compression Limiter for their assembly. The market knowledge gained by
our Application Engineering Department indicated that the wall thickness on
the Brass Compression Limiter could be reduced and still meet the majority
of the application requirements. Therefore, SPIROL has reintroduced the
new, improved and less expensive CL101 and CL111 Solid Brass Compression
Limiters.
In addition to the Series CL101 and CL111, SPIROL’s comprehensive line of
Compression Limiters includes the Series CL200 and CL250 (split seam) and
Series CL500 and CL550 (molded-in) designs.
www.spirol.com
:Design World::
Filed Under: Fastening + joining • locks • latches • pins
C2 lever latch offers auto-relock functionality and modern appearance
Covered compression latch enhances safety and reduces maintenance errors
Omron D41L hygienic guard locking switch is a tamper-proof solution for ensuring access control and workplace safety
Omron D41G guard lock and handle is an easy-to-wire and intuitive solution for safeguarding machine tools and robotic cells
