Southampton, PA – Plastic tubing manufacturer NewAge Industries, Inc. now stocks brass fittings in both barbed and push-to-connect styles to work with various plastic and rubber materials. U.S. -made of durable brass, applications include general purpose and industrial use, potable water systems, pneumatic control, robotics, and instrumentation.
The barbed brass fitting, called Thermobarb, is designed for use with soft, flexible tubing and reinforced hose such as PVC, polyurethane, silicone, thermoplastic rubber, Viton, and Hytrel. Thermobarb fittings are heavy duty and long lasting and offer temperature usage from -40°F to 180°F. Sizes range from 1/8 in. to 1 in. Clamps, which are also available from NewAge Industries, should be used for secure attachment.
Newloc, NewAge's brass push-to-connect fitting, works with semi-rigid and rigid tubing materials including nylon, polyethylene, and polypropylene. Newloc fittings are easy to install and disconnect – simply push the tubing into the fitting. For removal, push in the collet on the fitting and pull the tubing out. Newloc fittings handle full vacuum and temperatures from -10°F to 200°F. Sizes stocked range from 1/8 in. to 1/2 in.
Thermobarb and Newloc brass fittings are available in a wide variety of styles including male and female adapters, elbows, T's and Y's, connectors, reducers, swivel types, bulkhead options, and more. Both fittings are also offered in plastic materials for other application requirements.
Fluid Transfer Specialists
145 James Way
Southampton, PA 18966
Tel: 800-50-NEWAGE (800-506-3924) (toll-free)
or 215-526-2300
Fax: 800-837-1856
or 215-526-2190
E-mail: [email protected]
Product-specific web pages: www.newageindustries.com/tbrbbrasf.asp
and www.newageindustries.com/nwlocbrs.asp
About NewAge Industries
In business since 1954, NewAge Industries manufactures and fabricates thermoplastic and thermoset tubing and hose. The company offers one of the broadest product lines of tubing, hose, and fittings in the U. S. and, with its introduction of the AdvantaPure sanitary product line, is well suited to meet the demands of pharmaceutical and high purity applications. NewAge Industries prides itself on same-day shipment of 98% of orders for its core product lines. In 2006, NewAge Industries initiated an ESOP (Employee Stock Ownership Plan) for the benefit of both its employees and customers.
:: Design World ::
Filed Under: Factory automation, Appliance engineering + home automation, Automotive, ASSEMBLY, Tubing components, Clamps • locks • latches, MECHANICAL POWER TRANSMISSION
