Dayton OH — Measurement Specialties introduces a line of fast response probes which are available in small diameters to fit well into restricted areas. These thermistors are potted in a Mylar sleeve and then in a brass housing using a Stycast epoxy resin. With a response time of less than 1 second, and a temperature range of -40ºC to +125 ºC, these RoHS compliant probes are ideal for demanding HVACR applications, water flow monitoring, gas boilers, general instrumentation applications and more.
These fast response probes feature resistance of 10K Ohms at 25 ºC. They are available in a range of R/T curves, with custom tolerances available upon request. Additional information is available on these and other special-duty and general purpose sensors at www.meas-spec.com.
The Temperature Products Group of Measurement Specialties (MEAS) was created by the combination of BetaTHERM Sensors, YSI Temperature, HL Planar and most recently Atexis. Today they manufacture temperature components, probes and modules for virtually any application or industry.
Measurement Specialties, Inc.
www.meas-spec.com
Filed Under: Sensors (position + other), Sensors (temperature), Test + measurement • test equipment
