BroadWave Represents Single-Step Programmable Attenuator
By BroadWave Technologies | February 3, 2017
BroadWave Technologies recently introduced its Model 651-030-006, a single-step voltage controlled programmable attenuator designed for use in scientific instruments.
Key Features
  • The frequency range is DC-1 GHz
  • Attenuation range is 0-6 dB in a 6 dB step with ± 0.4 dB attenuation accuracy
  • Insertion loss is 0.6 dB nominal while VSWR is 1.30:1 maximum
  • Input power is 1 watt average with supply voltage +15 Vdc @ 30 mA nominal
  • The RF connectors are SMA female and the control solder terminal features a feed-thru capacitor to prevent leakage
EXE014 - Image 1
