Brunson Instrument Releases the Brunson EasyConnect Instrument Mounting System
By Test and Measurement Editor | April 17, 2013
Brunson Instrument Company  announced the availability of the Brunson EasyConnect instrument mounting system, the newest addition to their extensive line of instrument stand accessories. Using the Brunson EasyConnect, a metrology technician can instantly connect and disconnect a laser tracker, theodolite, articulating arm or optical instrument to/from a standard 3 ½”-8 external threaded mount. The unique, quick-action locking lever eliminates the sometimes awkward spinning of an instrument to connect or remove it from a stand.  A product video can be found at: www.brunson.us/p/240-1-easyconnect.htm
The Brunson EasyConnect mechanism locks metrology instruments firmly into place for maximum stability during use. Manufactured from stainless steel and anodized aluminum, the clamping system attaches to any instrument stand or other accessory having a 3 ½”-8 external threaded mount. A plummet sight is included for use with certain optical instruments.
Brunson Instrument
www.brunson.us
Test & Measurement Tips
Tagged With: brunsoninstrument
eBay
When to buy used test equipment
TRACO Power now sells cost-optimized 1-A POL converters with 6-to-36-V input range
eye diagram
Simpler debugging for Automotive Ethernet systems
E+H-Prosonic-flowmeter
Flowmeter for industrial water, feedwater, cooling water and condensate
