Brushless DC Motor And Compact Driver
By Design World Staff | May 17, 2007
The BLH speed control package brushless dc motor and 24 Vdc compact driver board includes four models from 15, 30, 50, and 100 W output. With speed regulation accuracy of + 0.5%, the motor operates at precise speeds from 100 to 3000 rpm.
Two gearhead types are available: the parallel shaft gearhead and the hollow shaft flat gearhead with a wide variety of gear ratios. The hollow shaft flat gearhead has a higher permissible torque ratio at higher gear ratios.
All four models come in motor only round shaft types, while the pinion shaft types are available in the three larger models with separate associated gearheads. The series is RoHS compliant.
Oriental Motor USA Corp.
www.orientalmotor.com
:: Design World ::
Filed Under: Motors • servo
