Brushless DC Motor & Compact Driver
By Design World Staff | April 4, 2007
Torrance, CA – ORIENTAL MOTOR USA CORP. introduces the new BLH speed control package composed of a brushless dc motor and a 24 Vdc compact driver board. The RoHS compliant BLH series encompasses four models ranging from 15, 30, 50, and 100 W output. The BLH has speed regulation accuracy of + 0.5%. The BLH brushless DC motor can be operated at precise speeds from 100 to 3000 rpm.
Two gearhead types are available: the parallel shaft gearhead and the hollow shaft flat gearhead with a wide variety of gear ratios. The hollow shaft flat gearhead has a higher permissible torque ratio at higher gear ratios. The 30, 50, and 100 W shaft gearhead motor packages are supplied in a combination motor gearhead package that is also available separately to facilitate changes or repairs. The 15 W brushless DC motor with hollow shaft flat gearhead is not available. The 15 W parallel shaft gearhead with BLH motor cannot be separated.
Motor only round shaft types are available in all four models, while the pinion shaft types are available in the 3 larger models with separate associated gearheads. Extension cables and external potentiometers are also available for all models as an option.
Oriental Motor USA Corp.
USA Headquarters Torrance, CA
Tel: (800) 418-7903 (toll-free)
Web: www.orientalmotor.com
About ORIENTAL MOTOR
Since its founding in Japan in 1885, ORIENTAL MOTOR has been a world leader in motor development. For over a century we have concentrated on technological advancement and product design improvement. This emphasis is evident in the sophisticated devices that we market today.
:: Design World ::
Filed Under: Factory automation, Automotive, Drives (servo) + amplifiers, MECHANICAL POWER TRANSMISSION, Motion control • motor controls, Motors • servo
