VANDALIA, OH – Johnson Electric introduces the Burgess V3NS series Miniature Micro Switch. The robust V3NS is engineered to deliver a minimum of 200,000 operations at 250 VAC, 6A, in a compact, IP67 rated 33 x 10.4 x 15.9 mm package. A range of internally fitted levers provide more stability than traditional types. Prewired, 6.8 mm or 4.8 mm faston terminal connection systems facilitate easy integration. They are UL, ENEC, IEC and CSA certified.
Their robust construction and functional advantages make Burgess V3NS miniature micro switches ideally suited for any number of demanding applications in the medical, building automation and security, leisure and fitness, material handling and transportation industries.
Johnson Electric
www.burgess-switch.com
Filed Under: ELECTRONICS • ELECTRICAL, Switches
