BXR-LE Electric Brakes for direct drive servo motor applications
By Leslie Langnau | August 10, 2018
BXR-LE electric spring applied brakes are ideal for small and precise servo motor configurations. Their unique compact and lightweight design optimizes servo drive performance and efficiency.
With accompanying voltage controller, the brake’s power consumption is stepped down to 7 Vdc after a split second of 24 Vdc for brake actuation.* When compared to most other
electric brakes, the revolutionary BXR-LE design provides just one-third power consumption and heat generation in one-half the overall size thickness. Specifications are:
• Maximum RPM: 6000
• Static friction torque range: 0.044 ft-lb to 2.36 ft-lb (0.06 Nm to 3.20 Nm)
• Ambient operating temperature 14°F – 104°F (-10°C to 40°C)
Additional applications for the BXR-LE brakes include:
• End effectors.
• Ball screw actuators.
• XYZ positioning tables.
• 3D printers.
Miki Pulley Industrial Brakes
www.mikipulley-us.com
Filed Under: 3D printing • additive manufacturing • stereolithography, Brakes • clutches
Tagged With: mikipulley
MagnaShear motor brakes make frequent start/stop cycles on cranes & conveyors maintenance-free
DELLNER BUBENZER debuts innovative and optimal performing disc brake series
MagnaShear motor brakes provide secure, no-maintenance holding brake solution for conveyors
Three torque-limiter options compared (and trip torque explained)
Going small with 3D printing
