Cable Carriers Minimize Downtime Costs
By Design World Staff | February 23, 2009
EAST PROVIDENCE, R.I. —  GÜDEL Inc. uses reinforced plastic cable carriers from igus® across its range of automated systems–from multi-axis robots and press-transfer systems, to factory-automation equipment and gantry robots.
The cable carriers guide and protect moving cables and hoses, helping to reduce the risk of cable failure and minimizing downtime for GÜDEL’s customers. GÜDEL supplies OEMs from many different industries, including the automotive and aerospace sectors.
GÜDEL uses System E4/100 Energy Tubes, which feature hinged, snap-open lids for easy access to cables and hoses. The robust plastic chains are completely resistant to harsh chemicals, hot flying debris, dirt and dust. They withstand high loads, fast accelerations and speeds, and can travel over long distances. This is key, as GÜDEL’s machines use up to 230 feet of Energy Tube at any one time and operate at speeds up to 23 feet per second.
GÜDEL also uses igus’ modular System E4/4 Energy Chain® cable carriers, which have easily-removable crossbars so that cables and hoses can be replaced quickly, saving the customer both time and money. System E4 cable carriers are suited to a wide range of demanding applications.
www.igus.com
Filed Under: Factory automation, Cables + cable management, Linear motion • slides, Safety systems + components
Solid-state relay characteristics and applications
