Manufacturers of equipment and electrical cabinets have designed a wide array of cable management alternatives to address the unique environments they support. These designs have included any number of mix and match product types. AerosUSA is pleased to announce the release of its Cable Entry System (CES), which allows the user to bring multiple cables, either terminated or non-terminated, safely and securely inside the equipment and/or the electrical cabinet. The key advantages of the CES are:
- Robust splittable frames with integrated NEMA 4X / IP66 gaskets
- Snap-in UL94-V0 split frame inserts with single and multiple port sizes for terminated cables
- Snap-in inserts include lock-in feature that holds insert in place prior to final assembly
- Stainless steel screws for easy assembly of loaded frames
- Double membrane cable entry plates for use with non-terminated cables
- Wide range of sizes available to meet various requirements
- Straight and 90-degree entry
Whether an application calls for new installation or retrofit, the breadth of the AerosUSA Cable Entry System will fit the needs of many applications. Find more details at the specific links below:
AerosUSA
aerosusa.com
