Cable Tray Coated With Reinforced Polyester
By COPE | June 4, 2018
Cope announces a new 5″ load depth for its COPE-GLAS™ Cable Tray enhancing the line of existing 2″, 4″, and 6″ depths.
Made of permanently bonded continuous glass filament coated with reinforced polyester (or vinyl ester resin) and alternating layers of glass mat, the COPE-GLAS Cable Tray is inherently chemical-resistant. This ability to withstand severely corrosive environments and improved weatherability can extend product life expectancy and dramatically reduce tray installation lifecycle costs.
The COPE-GLAS Cable Tray is strong and lightweight, allowing it to be installed quickly and easily. Because there are no sharp edges or burrs, long runs of armored cable can be installed with less chance for cable damage. Each straight section is designed with pre-punched holes to easily accept the splice plate fastener.
The COPE-GLAS Cable Tray is available in 10′ or 20′ lengths and meets Underwriters Laboratories Fiberglass Cable Tray Standard UL 568. A standard or special design can be fabricated for any indoor or outdoor application regardless of size.
Filed Under: Cables + cable management, Industrial automation
