Cable Tray Combo Clamp Speeds Installation With Tighter Hold
By Thomas & Betts | January 2, 2018
The new Cable Tray Combo Clamp from Thomas & Betts, a member of the ABB Group, is designed to be the only clamp or expansion guide needed to install any series of T&B® Cable Tray, regardless of side rail thickness.
The easy-to-install new accessory is designed to key into the rail flange on the clamp side when tightened, resulting in a rock-solid attachment in vertical or horizontal applications. The guide side holds the tray more gently, allowing it to expand or contract with temperature fluctuations. Strategically placed built-in bumps keep the part from twisting during installation.
The clamp’s “Guide” and “Clamp” sides are clearly marked to ensure proper installation. It can be used on strut or I-beam installations.
The Combo Clamp is available in aluminum, 316 stainless steel, and pre-galvanized or hot-dipped steel.
“The T&B Cable Tray Combo Clamp is a big step forward for installers who want a secure part that is quicker to use and easier to stock,” said Shaun Brannen, senior product manager – metal framing. “The single combination design fits any types of metallic T&B Cable Tray, which reduces the inventory of parts that installers need to carry. And the clearly marked sides and anti-twist functions make it very fast and easy to install.”
Filed Under: Cables + cable management, Industrial automation
