Motion control systems can vary from simple, straightforward single-axis direct-drive systems with little wiring to large and complex multi-axis robotic systems with a hornet’s nest of cables. This is usually where cabling, which was an afterthought, now takes center stage. Especially where there are lots of cables and wiring, cable management becomes an issue. A simple form of cable management uses twist-tie type bundlers that tie together groups of wires and cables. These are low cost and easy to use. The problem is that with more and more cabling, they become impractical. Also, if the wiring and cabling have to be suspended, bundling them together may pose weight problems which cause sagging and put undue strain on the cables. Using cable carriers is another option.
In this Design Guide, we detail cable carrier subtypes as well as the different designs into which cable carriers integrate.
"*" indicates required fields
By clicking 'Submit' above and registering for this content, I acknowledge and agree to Arrowfly's Terms and Conditions and to Arrowfly's use of my contact information to communicate with me about offerings by Arrowfly, its brands, affiliates and/or third-party partners, consistent with Arrowfly's Privacy Policy. In addition, I understand that my personal information may be shared with any sponsor(s) of the content, and that they may contact me directly about their products or services. Please refer to the privacy policies of such sponsor(s) for more details on how your information will be used by them.
Filed Under: Design Guides
