Cal Sensors Detector Can Detect Muzzle Flash From Over 100 Meters Away
By Randy Frank | April 30, 2013
Cal Sensors announces an optical detector technology capable of detecting muzzle flash from over 100 meters away, while minimizing false alarms. Optical muzzle flash detection systems offer a faster response, less false targets and potentially a more compact solution than other gunfire detection systems.
Operating at the speed of light an optical flash detection systems provide an almost instantaneous response to a gunfire event, providing real time detection capabilities. This also gives the targets the critical seconds needed to duck and apply counter-measures.
Unlike acoustic detectors, they do not detect other loud noises such as car backfires and can be designed to reject any optical signals that are outside the desired detection bandwidth. They are also not susceptible to the reverberation of sound off of structures in the vicinity of the gunfire. Therefore the determination of the location of the shooter is not hampered by the receipt of multiple signals from different locations for one event. A well-designed optical detector can clearly determine whether only one event transpired or if there are multiple shooters and their locations.
With superior detector sensitivity and measurement response time, Cal Sensors offers the ideal solution for flash detection systems.
Cal Sensors
www.calsensors.com
Sensor Tips
Filed Under: Sensor Tips
Tagged With: calsensors
What sensors are used in AR/VR systems?
What’s an acoustic leak detector?
How can sensors help cleanup waterways?
How do sensors improve wind turbine performance?
