CAMO introduces new code-compliant structural screws
By Michelle Froese | January 26, 2023
Known for delivering innovative tools and fasteners for deck builders, National Nail‘s CAMO brand takes its product innovation to a new level with a new line of high-performance structural screws.
“The CAMO team is excited to unveil CAMO Structural Screws, the next generation of structural fasteners to help builders with the deck structure and beyond,” said Doug Hutchings, VP of Product Development, National Nail. “The new screws offer builders excellent holding power and stronger connections.”
Certified IRC/IBC code-compliant and rigorously third-party tested and certified by DrJ Engineering, CAMO Structural Screws are built to last.
Engineered to start fast without pre-drilling, drive smooth, and hold strong, CAMO’s screw designs create the best structural fastener available. All structural screws feature CAMO’s proprietary PROTECH ULTRA 4 coating, a four-layer system for industry-leading corrosion resistance and tested 2X longer than industry standards.
The Ledger, Multi-ply and Truss screws also do double-duty, requiring fewer fasteners per job and less SKUs for dealers. Unlike most structural screws, all CAMO structural screws can be used for interior and exterior projects.
Certified IRC/IBC code-compliant and rigorously third-party tested and certified by DrJ Engineering, CAMO Structural Screw applications include the deck substructure, internal framing, ledger, and general construction.
The CAMO Structural Screw product line includes:
CAMO Truss Screws… these six-inch screws helps contractors make connections easier, faster, and better. Truss Screws replace hurricane ties for general interior construction and exterior decking applications. The hands-free Truss Guide included in every pail helps contractors fasten at the right angle every time. Above and beyond most structural screws, the CAMO Truss screw can be used in interior wall and exterior beam-to-joist connections.
CAMO Multi-Ply Screws are available in specific lengths for both sawn and structural composite lumber beams, replacing through-bolts and nails for faster, stronger, more secure connections. Three screws do double-duty as Ledger Screws.
CAMO Ledger Screws are offered in a variety of lengths. The new CAMO Ledger Screws are a faster, less costly way to install ledger boards. The screw’s flat head finishes flush with the material, so it doesn’t get in the way of joist hangers or other materials. These screws can also be used in multi-ply applications.
Framing Screws are available in 2-1/2 and 3 inches, and are designed with superior holding power for wood-to-wood framing connections, deck blocking and interior/exterior general construction projects.
CAMO’s Multi-Purpose Screws are offered in flat and hex-head designs, replacing lag bolts and through-bolts for framing. In addition to CAMO’s PROTECH ULTRA 4 Coating, they are available in hot-dip galvanized options for coastal applications.
New CAMO Structural Screws are backed by a lifetime warranty when installed according to CAMO guidelines.
Tagged With: camo, nationalnail
  • Tech Toolbox: Designing for cleanrooms
