Canfield Connector’s Compact Reed and Electronic Sensors
By Patrick Curran | July 24, 2009
Canfield Connector’s Series 8000 compact reed and electronic sensors are
designed for sensing applications on round cylinders from 9/16” to 4” and tie-rod cylinders from 3/4” to 8” bore. They are CSA approved for the US and Canada and most are designed to meet NEMA 4 specifications.
They are compatible with wash down applications as well as with intrinsically safe barriers, have an encapsulated circuit and an operational temperature range of -20° to +80°C. The Series 8000 reed versions have a voltage range from 0 — 120 VAC/VDC Hz and a high current capacity up to 0.5 Amps. The electronic versions have a voltage range from 6 — 24 VDC and a current capacity of 0.3 Amps. A high intensity LED light is standard on most models. The sensor’s small package fits on the smallest cylinder and accommodates installation with a tight fit.
Canfield Connector
www.canfieldconnector.com
Filed Under: Sensors (proximity), TEST & MEASUREMENT, ELECTRONICS • ELECTRICAL
