Capacitors 3D printed on the DragonFly system deliver accuracy
By Leslie Langnau | September 12, 2019
Nano Dimension Ltd., announced it has developed 3D printed capacitors with the DragonFly additive manufacturing system. These capacitors are embedded in the body of the additively manufactured printed circuit boards (PCBs), saving space and eliminating the need for assembly. This breakthrough in the additive manufacturing of electronics validates the manufacturing applicability of built in capacitors in PCBs printed with the award-winning DragonFly system, the only precision additive manufacturing system of its type.
Nano Dimension’s extensive testing with capacitors of different 3D dimensions have shown consistent results with statistically validated data. The repeatability results show less than 1% variance. The technology uses the same dielectric and metal traces as in the additively manufactured PCB yielding capacitors with a capacitance range from 0.1nF to 3.2nF. The successful results are based on more than 260 tests with 30 different additively manufactured capacitors dimensions.
By integrating capacitors using additive manufacturing, electronics designers and manufacturers can avoid what is often a time consuming, multi-step assembly process, as the DragonFly prints the entire capacitor and PCB in one print job. This allows companies to reduce the fabrication time and overcome many of the challenges imposed by traditional production techniques.
Additively manufacturing capacitors within the inner layers of circuits also can free space to meet the increasing trend towards miniaturization and flatness of electronic devices for consumer, industrial and military applications. With extra space, designers may pack more functionality on the circuit board and shrink component size – all without compromising reliability.
Capacitors of this kind are primarily used to filter electrical noise and ripple voltage for a range of applications, including RF transmission lines, audio processing, radio reception and power circuit conditioning.
“The test results clearly show that with the DragonFly system our customers can achieve repeatability comparable to that of traditional processes in short run manufacturing of capacitors using 3D printing,” said Amit Dror, CEO of Nano Dimension. “Along with high accuracy, miniaturization and space saving on the board, these are key factors in the electronics production process and next generation electronics applications.”
Nano Dimension
www.nano-di.com
Filed Under: 3D printing • additive manufacturing • stereolithography, Capacitors
Tagged With: nanodimension
PCB mills
September 2020 Special Edition: 2020 Additive Manufacturing Handbook
The Decision-Makers’ Guide to Additive Manufacturing: Explore the essentials of today’s AM environment and improve your results
Top 3 reasons why you should consider additive manufacturing today for production parts
