Electromechanical Plug-In Relays come with screw and push-in terminal sockets and accessories that include busbars, retention clips, ID tags, and protection module. The slim, compact design of the RPYS is ideal for electronic and automation panels with limited space. Its 13-mm-wide footprint saves customers more than 30% of utilized space when compared to other industrial plug-in relays. Matching sockets are available in both screw and push-in terminals versions for quick and easy wiring as well as vibration resistant connections. Wiring is further simplified by interconnecting multiple relays and sockets by means of busbars.
Features of the RPYS Series include:
SPDT 10A or DPDT 5A contact ratings
12.6mm width
Nominal coil voltage: 12VDC, 24VDC, 24VAC, 115VAC, and 230VAC
Basic and Test button + LED versions
Bidirectional LED indicator with polarity protection
Matching screw and push-in terminal sockets
Accessories: bus jumpers, ID tags, retention clips, protection diode module
Agency approvals: RoHS compliance, cURus and CE certification
The RPYS Electromechanical Plug-In Series Relays are specifically designed to meet requirements in the industrial and building automation markets, including Food and Beverage equipment, Automated Doors and Access Controls, Plastics & Rubber machines, HVAC systems, Building automation, Lifts and Escalators, Packaging equipment, and Mining machinery.
CARLO GAVAZZI Inc., 750 Hastings Lane, Buffalo Grove, IL 60089, 847.465.6100, Fax: 800.222.2659, [email protected], www.GavazziOnline.com.
You may also like:
Filed Under: TECHNOLOGIES + PRODUCTS, Relays
