    • Subscribe!
Cast Platen Heaters
By Design World Staff | August 24, 2007
(Cary, Illinois) -Durex Industries manufactures cast platen heaters as a durable heat source for commercial applications.  Platens can be manufactured with thickness from ½” and up.
A rugged tubular heating element is distributed evenly to provide a uniform temperature pattern across the surface.  CNC machining operations provide surface finishes from 125 RMS to 8 RMS, depending on the application.  The standard flatness tolerance is .005″, but other tolerance specifications are available.
Secondary coatings such as Teflon  or Nickel can be added to enhance surface performance characteristics, as required.  These platen heaters can also accommodate a host of mounting options, including threaded holes, cast-in stud terminals or mounting tabs.  The efficient heat transfer characteristics of the cast-in design offer higher wattage outputs and longer life cycles than other heaters used in these applications.
www.durexindustries.com
:: Design World ::
Filed Under: Machine tool industry + subtractive manufacturing, Terminal blocks
30i-B-Plus-5AxisScreen-web-(002)
Optimized 5-axis post processor for FANUC CNCs
Impact sensors monitor for brain injury in sports and recreation helmets
Digital manufacturing makes a better prosthesis, enabling paralympic athlete to compete in Winter X Games
SendCutSend-basket-IMG_2080
How to design for laser cutting
    • Subscribe!
