PIC Wire & Cable – A Division of The Angelus Corp., has launched its new CAT7 Ethernet DataMATES cables. PIC’s CAT7 cables deliver 10G data performance in rugged environments that require low loss interconnect solutions that are also lightweight and flexible.
CAT7 cables are used in military and civil data applications, from airplanes and helicopters to land vehicles and mobile shelters. Cables are designed to meet performance requirements for high speed data applications, including cabin management systems, ethernet backbones, computers, servers and low skew video.
PIC’s new CAT7 cables offer 10G performance at 600MHz, the highest frequency available for 10G Ethernet speeds. Eric Witkowski, Product Specialist, said, “CAT7 cables are engineered to perform at higher frequencies, while still providing 10G data speeds. Our cables are designed with individually shielded pairs to greatly reduce the amount of pair-to-pair signal interference and protect the 10G performance.” The highly shielded cable is also lightweight, flexible and laser markable for easy cable routing and identification in small environments. In conjunction with the cable release, several new matching connectors have been designed to address application requirements.
PIC Wire & Cable
www.picwire.com/cables/data-mates
Filed Under: Cables + cable management, Ethernet — cables • hubs • switches
